Panoramica Recensioni
Supporto Aerobar/TT per computer da bicicletta ELEMNT
14,99 €
Altre viste
SKU# WFCC1M3
14,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Recensioni
Panoramica sul prodotto
Il nostro supporto Aerobar/TT per computer da bicicletta con GPS Wahoo ELEMNT è realizzato in plastica leggera e durevole e rappresenta la posizione di visione ideale durante il triathlon o una prova a cronometro.
  • Adatto a estensioni da 22,2 mm Aerobar
  • Peso: 0,3 oz
  • Funziona con ELEMNT, ELEMNT BOLT ed ELEMNT MINI (Nota: BOLT perde il vantaggio aerodinamico con questo supporto)
  • Aerobar/TT Mount for ELEMNT Bike Computers is rated 3.3 out of 5 by 16.
    Rated 4 out of 5 by from Bolt front bike mount Very well designed and easy to install. Only issue: build tether into mount.
    Date published: 2018-09-24
    Rated 5 out of 5 by from it works as advertised easy to mount, fits over handlebar bag, positions the Bolt for comfortable glances while riding FS gravel roads. I bought 2 so I can use Bolt on either bike.
    Date published: 2018-09-07
    Rated 4 out of 5 by from Looks nice I haven’t had a chance to use yet I’m still waiting on my TT bars
    Date published: 2018-08-07
    Rated 2 out of 5 by from Nice, but need a better fit. I bought this for use with my Elemnt Bolt on the aero bars of my TT bike. Its certainly a tiny, lightweight mount. However, as its designed it doesn't fit tightly enough around the bars. The mount moves around if you press the buttons on the Bolt without providing back pressure and large bumps will also cause the mount to move. It needs rubber isolator or a better clamping design. It is far cheaper than some of the other TT mounts available, but its better to spend the little extra for a better mount.
    Date published: 2018-08-01
    Rated 2 out of 5 by from BEWARE! Not compatible with ALL aero bars This mount is just slightly too small to mount my Syntace aerobar. Quite disappointed by this.
    Date published: 2018-07-03
    Rated 4 out of 5 by from Works perfect but becareful! Bought this for TT bike and it works great with only one caution. Do not overtighten the Allen screw that holds in place as it will pull the nut out of the plastic on the other side of the mount. Used a little epoxy am definitely pressed back into place and just snugged it up and it works great! Mane a little more robust nut on the other side and a washer would prevent this problem, but having the element there for use during ITT is worth all the effort !! Great product!
    Date published: 2018-06-12
    Rated 2 out of 5 by from Needs work It works....... but 1. this should come with a rubber strip to stop the mount from slipping. 2. The curved plastic should curve up, not down to allow the computer to 'recess' into the aero bars. After all, this would be more aerodynamic IMHO. 3. Cheap plastic. Seems like it would break and is not durable.
    Date published: 2018-06-07
    Rated 4 out of 5 by from Does the job Shame the interface can't be common to Garmin as I've had to replace the mounts on several bikes. This one does the job, though you may want to add a wrap of friction tape under the clamp if your aero bars are on the smaller side of the range. Also, too bad that the aero interface with the Bolt wasn't retained for the application where customers obviously will care about aero consideration!
    Date published: 2018-05-01
    • y_2019, m_1, d_22, h_19
    • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
    • cp_1, bvpage1
    • co_hasreviews, tv_2, tr_14
    • loc_en_US, sid_WFCC1M3, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
    • clientName_wahoofitness
    • bvseo_sdk, p_sdk, 3.2.0
    • CLOUD, getContent, 6.05ms
  • Peso: 0,3 oz
  • Caratteristiche
    Specifiche
    Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
    Recensioni
    AVVISO:cancro e danni agli organi riproduttivi - www.P65Warnings.ca.gov
    Powered By OneLink
