Supporto frontale aerodinamico per ELEMNT BOLT
19,99 €
Altre viste
Esaurito
SKU# WFCC3M1
19,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Recensioni
Panoramica sul prodotto
Il nostro supporto integrato in attesa di brevetto per il computer da bicicletta con GPS ELEMNT BOLT è realizzato in plastica leggera e durevole. Include inoltre una vite di bloccaggio opzionale conforme UCI per collegare ELEMNT BOLT alla bicicletta per la pesatura.
  • Adatto a manubri tondi da 31,8 mm
  • Peso: 0,9 oz
  • Funziona esclusivamente con ELEMNT BOLT
  • ELEMNT BOLT Aerodynamic Out Front Mount is rated 4.0 out of 5 by 42.
    Rated 5 out of 5 by from Great Device! The functionality and ease-of-use is great. I did have one issue with not being able to load private segments from Strava onto my device, but they’ve already fixed the problem with an update. Very responsive and dynamic company
    Date published: 2018-11-29
    Rated 5 out of 5 by from The Best Hands down the best computer I have ever owned. It does it all and does it reliably, and effectively. Everything is so intuitive, it’s like Apple engineers designed it. It even controls my smart trainer and allows me to virtually ride any route that I have created. If you are on the fence, my advice is to jump. You won’t be sorry or have buyers regret like some of my buddies do with “another” brand. It works and has everything you will ever need.
    Date published: 2018-11-25
    Rated 2 out of 5 by from Poor quality I bought the Wahoo Elemnt bundle roughly 4 months ago and setup fine. After a few rides I noticed the out front mount was a little loose so I tried to tighten the screw until the clamp locked into my bars. Unfortunately the screw seemed to thread through the top part of the mount making the mount useless. I thought this was human error and ordered another mount for £30 only to find out it has done the same while using a torque wrench to make sure I wasn’t over tightening. I’ve been told to try using electricians tape on my bars to make it seem wider but surely this isn’t the best fix for a £30 piece of plastic? Real shame as I love my wahoo products but this was a real let down. I would only recommend this product if you have smashed your original one has smashed.
    Date published: 2018-11-12
    Rated 5 out of 5 by from Precise Mount Ordered an extra mount to my second bike. This mount is the complement to a complete aero advantage.
    Date published: 2018-10-08
    Rated 4 out of 5 by from Excelente product excellent product, very intuitive to use and configure. Just need to improve the application to choose the type of bicycle (indoor, route, MTB, others). I also suggest incorporating an editor of maps and routes of wahoo.
    Date published: 2018-10-07
    Rated 5 out of 5 by from Simple to setup, small and big enough for data Bought this for my daughter and she is loving it. Simple setup and seamless integration with 3rd party apps. Small for sleek design and aero yet large enough data fields to see with no problems. Love the color accent as well.
    Date published: 2018-08-21
    Rated 5 out of 5 by from User friendly Very intuitive to use. By far the best computer i have had so far.
    Date published: 2018-08-12
    Rated 1 out of 5 by from Won't fit on bar The mount is way bigger than my bar. No shims included so I had to cut up some garden hose to kind of get it to fit. Looks terrible on the bike.
    Date published: 2018-08-03
    • y_2019, m_1, d_22, h_19
    • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
    • cp_1, bvpage1
    • co_hasreviews, tv_2, tr_40
    • loc_en_US, sid_WFCC3M1, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
    • clientName_wahoofitness
    • bvseo_sdk, p_sdk, 3.2.0
    • CLOUD, getContent, 13.85ms
  • Peso: 0,9 oz
  • Caratteristiche
    Specifiche
    Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
    Recensioni
    AVVISO:cancro e danni agli organi riproduttivi - www.P65Warnings.ca.gov
    Powered By OneLink
