Panoramica Recensioni
Supporto K-Edge Aero Race per ELEMNT BOLT
24,99 €
K-Edge Aero Race Mount for ELEMNT BOLT is rated 4.2 out of 5 by 5.
  • y_2019, m_3, d_20, h_2
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_WFCC3M3, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 86.61ms
24,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Panoramica sul prodotto
Progettato in collaborazione con K-EDGE per fornire la massima combinazione di forza K-EDGE e vantaggio aerodinamico Wahoo BOLT. Testati e utilizzati da team dell'UCI World Tour, BORA Hansgrohe e Katusha Alpecin.
  • Manubri da 31,8 mm
  • Colore: nero
  • Alluminio lavorato CNC
  • Design aerodinamico
  • Bloccabile per i requisiti di peso UCI
  • Peso: 35 grammi
Rated 5 out of 5 by from Great product Looks good, and my Wahoo Elmnt Bolt is more strongly fixed than with the usual mount!
Date published: 2018-08-13
Rated 5 out of 5 by from Special Mount Special and beautiful race mount. The adjustment about handlebar is ideal,
Date published: 2018-07-16
Rated 5 out of 5 by from Solid addition to the Elemnt Bolt I bought this because I found the plastic aero mount that comes with the Bolt a little flimsy. It naturally weighs more than the plastic alternative, 35g compared to circa 20g. While the plastic mount appears to look more aero (this holds the Bolt a mm or two further away) this is absolutely solid - and keeps the computer vibration and movement free. The difference is noticeable when using turn-by-turn navigation, looking at the screen for short periods of time, as opposed to just glancing a look of your vital stats.
Date published: 2018-05-11
Rated 4 out of 5 by from Well made with one small flaw I have been awaiting this product for some time as my bars are semi aero and the standard mount doesn't quite sit correctly. This mount solved the original issue but I have found that after only a few uses the device rattles around on the mount! It sounds like a cable knocking against my frame and after going through each cable individually finally realised its the Element making all the noise. I'm not sure if it is the mount or my device that has the issue but annoying either way.
Date published: 2018-08-30
Rated 2 out of 5 by from Not as aero as you would expect for the price I bought this because the Wahoo mounts are perpetually out of stock. The cnc aluminum is nice, the clamp is first quality. There is a large square hole in the bottom of the mount, which the Wahoo mount does not have. I guess K-edge does not understand that one of the main marketing points of the Bolt is its aerodynamic design.
Date published: 2018-07-23
  • cp_1, bvpage1
  • CLOUD, getReviews, 4.29ms
  • Colore: nero
  • Peso: 35 grammi
Caratteristiche
Per maggiori informazioni, vedi Domande frequenti
Specifiche
Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
Recensioni
Powered By OneLink
