Panoramica Recensioni
Supporto frontale per computer da bicicletta ELEMNT
19,99 €
Out Front Mount for ELEMNT Bike Computers is rated 4.1 out of 5 by 22.
  • y_2019, m_3, d_20, h_2
  • cp_1, bvpage1
  • co_hasreviews, tv_3, tr_19
  • loc_en_US, sid_WFCC1M1, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 5.27ms
19,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Panoramica sul prodotto
Il nostro supporto frontale per il computer da bicicletta con GPS ELEMNT è realizzato in plastica leggera e durevole ed è ideale per tenere sotto controllo i dati e il percorso stradale.
  • Adatto a manubri tondi da 31,8 mm
  • Peso: 0,7 oz
  • Funziona con ELEMNT, ELEMNT BOLT ed ELEMNT MINI (Nota: BOLT perde il vantaggio aerodinamico con questo supporto).
Rated 5 out of 5 by from Makes viewing computer easy Easy to install the Out Front Mount. Has made monitoring my ride status easier and more efficient.
Date published: 2018-11-15
Rated 5 out of 5 by from Puts the Bolt right where you need it Easy to install and holds the bolt firmly in place.
Date published: 2018-07-17
Rated 5 out of 5 by from Does what it says on the tin Holds my ELEMNT in place at a much lower cost than many of the aftermarket options. Highly recommend.
Date published: 2018-06-18
Rated 5 out of 5 by from It's a mount! It's hard to write a review on something that is simple and does what it should. I will say this, other brands of the same size computer want you to use a little tether cord in case it comes loose. That notion alarms me. The elemnt mount is rock solid. Through a lot of road and harsh gravel riding it has never so much as twitched loose. It works like it should. I always feel confident it will keep the computer safe.
Date published: 2018-01-19
Rated 5 out of 5 by from Sturdy mount Pleased with this mount. It holds my Elemnt securely and there's no vibration. In my opinion having the Elemnt a few inches ahead of the bars gives a more comfortable view than a stem mount
Date published: 2017-08-04
Rated 5 out of 5 by from Best Elemnt Mount On my drop-handlebar touring bike I replaced a handlebar/stem mount with this and it's a big improvement. It mounts securely and the Elemnt screen is easier to read, neither of which was true for the handlebar mount. Just make sure you adjust it so that the Elemnt isn't in contact with the road when you turn the bike upside down to mend a puncture.
Date published: 2017-07-30
Rated 5 out of 5 by from Solid mount, built well, quality product! Bought this product for one of my bikes after picking up the Elemnt. I love it. It shipped quickly and is built with quality. It doesn't shake, rattle, or shift. Love it!
Date published: 2017-05-12
Rated 5 out of 5 by from Quality Very sturdy, even has some rubber pads built in to make the mount stay in place with a relatively lower amount of pressure. I prefer this over the k-edge.
Date published: 2017-04-05
  • cp_1, bvpage1
  • CLOUD, getReviews, 4.89ms
  • Peso: 0,7 oz
Caratteristiche
Per maggiori informazioni, vedi Domande frequenti
Specifiche
Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
Recensioni
Powered By OneLink
