Panoramica Recensioni
Adattatore montaggio a un quarto di giro
14,99 €
Quarter Turn Mount Adapter is rated 4.5 out of 5 by 11.
  • y_2019, m_3, d_20, h_2
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_10
  • loc_en_US, sid_WFCC1M5, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 53.65ms
14,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Panoramica sul prodotto
Con questo adattatore puoi convertire qualsiasi supporto per computer da bicicletta da un quarto di giro Garmin in un supporto per computer da bicicletta Wahoo ELEMNT.
  • Peso: 3 gr
Rated 5 out of 5 by from Simple and saves replacing all your Garmin mounts. Simple! Fits perfectly into Garmin mounts. You will only need one, even if you have several bikes as it as easy to move the adaptor, as it is to move your Cycling computer from bike to bike. Perhaps a little expensive but does save you having changie all your Garmin maps. So you could argue it’s good value!
Date published: 2019-02-24
Rated 5 out of 5 by from Easy! Thanks, used this so i can mount my bolt to the venge vias mount! THANK YOU!
Date published: 2018-12-14
Rated 5 out of 5 by from Genius Little Adapter Bought this to attached to the garmin integrated stem mount on my BMC Roadmachine. Works perfect!
Date published: 2018-12-10
Rated 5 out of 5 by from Perfect solution! Does exactly as expected and a good positive action. Wahoo Elemnt perfectly locked inlace in a Garmin mount!
Date published: 2018-10-20
Rated 5 out of 5 by from Works perfectly - exactly what I needed I'm stuck with a Giant computer mount with a Garmin insert, as it's the only mount that works well with Giant's proprietary "Conduct" hydraulic brake system. I was awkwardly cable-tying my Elemnt off to the side on the handlebars, but it was ugly and wobbly. I'm really glad I found this adapter - it fits into the Garmin insert perfectly, and the Elemnt easily snaps in and out.
Date published: 2018-09-26
Rated 5 out of 5 by from It Works! I have a very nice ENVe out front mount. With this adapter my Bot lives happily where I want it to be. A little overpriced, though.
Date published: 2018-09-25
Rated 5 out of 5 by from Precise fitting Bought this mount adapter for my garmin stem mount. I would recommend this adapter for its narrow height and presice fittting. Maybe a bit expensive.
Date published: 2018-08-20
Rated 4 out of 5 by from Garmin adaptor rocks Finally will be able to use all my previous mounts
Date published: 2018-11-20
  • cp_1, bvpage1
  • CLOUD, getReviews, 2.35ms
  • Peso: 3 gr
Caratteristiche
Per maggiori informazioni, vedi Domande frequenti
Specifiche
Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
Recensioni
Powered By OneLink
