Panoramica Recensioni
Mozzo Shimano
59,99 €
Mozzo Shimano
Per KICKR versione 2014 e versione 2016
Esaurito
Shimano Freehub for KICKR Smart Trainer is rated 3.8 out of 5 by 4.
  • y_2019, m_3, d_18, h_23
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_000-0396, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 95.4ms
59,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Panoramica sul prodotto
Questo mozzo rende il KICKR compatibile con le cassette Shimano a 9, 10 e 11 velocità. Funzionerà solo con le versioni 2014 e 2016 di KICKR.
Nota: occorre eseguire l’installazione! Please visit our support site forShimano Adapter instructions. La cassetta Shimano e l’anello di blocco non sono inclusi. Assicurati di disporre di tutti gli strumenti adeguati prima dell'acquisto. Se non desideri eseguire l’installazione da solo, il negozio di biciclette della zona disporrà di tutti gli strumenti e il know-how per farti montare in sella in un baleno!
Rated 5 out of 5 by from Fixed my freewheeling issue My kickr wouldn’t freewheel, it ended up being the freehub body wearing away. Luckily the axle it mounts to is undamaged and it works perfectly with the new spacer and freehub
Date published: 2018-03-13
Rated 5 out of 5 by from Perfect! On time, easy install, great support! After thousands of miles in my kickr, this was a much needed replacement of a component that is expected to wear over time. Replacing greatly improved ride fee and fluidity on my kickr.
Date published: 2018-02-05
Rated 4 out of 5 by from Few mishaps but good service in the end. After some misunderstandings between costumer service and I we found a good solution. Glad I got the freehub it's nice my Kickr works again.
Date published: 2017-04-13
Rated 1 out of 5 by from Not necessary I bought this item (at the same time as buying my KICKR smart trainer) as a result of reading a previous purchasers review that said you need to change the supplied hub if you have a 10 speed shimano gear set on your donor bike. On closer inspection the original/supplied hub is Shimano esk and all I needed was a spacer so I returned the hub.
Date published: 2017-11-17
  • cp_1, bvpage1
  • CLOUD, getReviews, 4.44ms
Caratteristiche
Per maggiori informazioni, vedi Domande frequenti
Specifiche
Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
Recensioni
Powered By OneLink
