ELEMNT RIVAL
RUNNING WATCH
ELEMNT RIVAL creates a seamless training and racing experience for runners. Powered by proven ELEMNT technology to provide a simple user experience to set up and customize the device to fit your lifestyle. With optical heart rate, barometric altimeter, ceramic bezel and water resistance up to 50m, ELEMNT RIVAL is your next GPS watch for running.
ACQUISTA ORAJim Walmsley - Western States 100 Champion
MAI. PERDERE. LA CONCENTRAZIONE.
ELEMNT RIVAL uses the intuitive ELEMNT OS to make the setup, customization and user experience of this GPS sport watch simple and seamless. Featuring a durable ceramic bezel, RIVAL boasts accurate GPS to track and record your runs, whether on the track, road or trails.
SEMPLICE DA MONITORARE
With powerful and intelligent running features, ELEMNT RIVAL tracks time and workout data with minimal interaction between you and your watch, letting you concentrate on the task at hand – your training and race-day performance.
ACQUISTA ORA
FREQUENZA CARDIACA OTTICA
Check your heart rate and calorie data at a glance with ELEMNT RIVAL's built in optical heart rate. Set your zones in the ELEMNT Companion App to keep a pulse on your efforts.
ALLENAMENTI PIANIFICATI
Sync your TrainingPeaks calendar or choose one of our pre-loaded Wahoo Sports Science workouts to execute on RIVAL. As you run, interval prompts and target tracking are built into your sessions to keep you on pace.
PROFILO DI CORSA SU PISTA
Use RIVAL's tracking running feature to snap to the nearest 100m distance on any standard 400m track to ensure your workout data is as accurate as possible.
TIMER RIPOSO LAVORO
Build out the intervals to fit your training. Create set periods for work and rest time and get prompted notifications during your workout to stay on track.
Di semplice visualizzazione
Con un ampio display a colori che utilizza un sensore di luce ambientale e Perfect View Zoom™, ELEMNT RIVAL funziona in qualsiasi condizione di luce per avere la possibilità di visualizzare i dati di allenamento più importanti in qualsiasi momento.
ACQUISTA ORA
SENSORE DI LUCE AMBIENTALE
Il sensore di luce ambientale di ELEMNT RIVAL rende visibili i dati di allenamento anche quando le condizioni di illuminazione sono tutt’altro che ideali.
MIRARE
ALLA TUA ATTENZIONE
Utilizzando Perfect View Zoom™, lo smartwatch ELEMNT RIVAL consente di ingrandire e ridurre i dati specifici dell’allenamento in modo da poter visualizzare facilmente le metriche più importanti.
CRISTALLINO
ELEMNT RIVAL è realizzato con Gorilla Glass, uno schermo altamente affidabile e resistente agli urti per far sì che il tuo orologio sia duro almeno quanto la tua routine di allenamento.
SCELTE CROMATICHE
Con una risoluzione di 240x240, ELEMNT RIVAL mostra i dati sulle prestazioni su un display LCD a 64 colori personalizzabile e facile da vedere in piscina o durante una corsa.
Facile da usare
With the most intuitive user interface, ELEMNT devices have dramatically changed the way athletes interact with their devices. ELEMNT RIVAL is optimized to give runners a focused advantage.
ACQUISTA ORAL’ESPERIENZA ELEMNT
L’app complementare ELEMNT è dotata di un’interfaccia smartphone intuitiva che ti guida attraverso la configurazione, la creazione di profili di allenamento, la personalizzazione delle schermate degli allenamenti e il collegamento di ELEMNT RIVAL alle tue app fitness preferite e ai sensori wireless.
NOTIFICHE INTELLIGENTI
Con ELEMNT RIVAL puoi trovare facilmente e in tempo reale gli amici che si stanno allenando. E con la possibilità di ricevere email, SMS e avvisi sul telefono, rimani sempre in contatto, anche quando sei lontano.
IL PIÙ CONNESSO
Che tu stia pedalando, correndo, nuotando o semplicemente allenandoti, ELEMNT RIVAL può essere collegato alle app di allenamento e ai sensori wireless più popolari per offrire un’esperienza di allenamento completa.
SINCRONIZZAZIONE WIRELESS
Con ELEMNT RIVAL puoi dire addio ai cavi: niente più tempo perso in collegamenti con il computer portatile per sincronizzare i dati dell’allenamento o aggiornare il software dell’orologio.
TUTORIAL BASATI SU APP
Per conoscere a fondo ELEMNT RIVAL, utilizza i tutorial dettagliati forniti. Grazie alle istruzioni facili da seguire, scoprirai le caratteristiche uniche di RIVAL per ottenere il massimo dal tuo orologio.
WORKOUT EDITOR
Use Workout Editor on the ELEMNT Companion App to correct your segment timing on the Track Running or Triathlon profiles for variations between your watch and the official race results.
CONTROLLO KICKR
Con ELEMNT RIVAL l’allenamento in bicicletta si fa al chiuso. Collegandoti ai rulli smart Wahoo KICKR, hai il controllo completo del rullo smart scelto da Jan Frodeno, campione olimpico e tre volte vincitore del campionato mondiale di IRONMAN.
SPECIFICHE
SPECIFICHE TECNICHE | |
Dimensioni | 46,5 x 46,5 x 15,3 mm |
Dimensioni del display | 30,4 mm di diametro |
Tipo di display | Colore |
Risoluzione del display | 240 x 240 |
Materiale lente | Gorilla® Glass |
Materiale della lunetta | Ceramica |
Materiale della cassa | Polimero di nylon |
Materiale del cinturino | Silicone |
Lunghezza della cinghia | 25,4 cm Si adatta a polsi con circonferenza compresa tra 140 mm e 240 mm |
Peso | 53 g |
Batteria | Ricaricabile agli ioni di litio |
Durata della batteria | Modalità smartwatch: 14 giorni Modalità GPS o HR: Fino a 24 ore |
Funzionalità GPS | Integrato |
Satelliti supportati | GPS e GLONASS |
Classe di impermeabilità | 5 ATM (resistente all’acqua fino a 50 metri) |
Pulsanti di zoom Perfect View | Sì |
Sensore di luce ambientale | Sì |
CONNETTIVITÀ | |
Connettività wireless | ANT+® e BLUETOOTH® |
Compatibilità del sensore | ANT+®, BLUETOOTH® e ANT+ FE-C |
Compatibilità telefono | iPhone e Android |
SENSORI | |
Altimetro | Sì |
Bussola | Sì, basato su GPS |
Giroscopio | No |
Accelerometro | Sì |
Termometro | No |
CARATTERISTICHE OROLOGIO | |
Ora/data | Sì |
Sincronizzazione ora con GPS | Tramite app complementare ELEMNT |
Ora legale automatica | Tramite app complementare ELEMNT |
Timer | Sì |
Cronometro | Sì |
CARATTERISTICHE INTELLIGENTI | |
Configurazione app complementare | Sì |
Schermo personalizzabile | Sì |
Notifiche | Chiamata, testo, email, WhatsApp, segnale, linea, telegramma e WeChat |
Monitoraggio in tempo reale | Tramite app complementare ELEMNT |
Controlla la musica dello smartphone | Sì (solo iOS) |
Aggiornamenti automatici degli allenamenti | Sì |
FUNZIONI DI MONITORAGGIO ATTIVITÀ | |
Contapassi | Sì |
Consumo calorico | Sì, calorie attive |
Piani saliti | No |
Distanza percorsa | Sì |
Minuti di intensità | No |
Tempo di allenamento | Sì |
Distanza settimanale nuoto/bicicletta/corsa | Sì |
Profili attività | Ciclismo indoor (KICKR), ciclismo all’aperto, corsa all’aperto, tapis roulant, corsa sulla pista di atletica, nuoto in vasca (piscina), nuoto in acque libere, forza, yoga |
CARATTERISTICHE DELL’ANALISI DELL’ALLENAMENTO | |
Zone HR | Sì |
Calorie HR | Sì |
Parametri di trasmissione Bluetooth e ANT+ | Frequenza cardiaca, passo e cadenza di corsa |
Velocità e distanza GPS | Sì |
Pagine dati personalizzabili | Sì |
Profili attività personalizzabili | Sì |
Pausa automatica | Sì |
Giro automatico | Sì |
Giro manuale | Sì |
Prompt audio | Sì |
Ora finale | Sì |
Attività multisport automatiche | Sì |
Attività multisport manuali | Sì |
Blocco pulsante | Sì |
Cronologia attività sull’orologio | Sì |
INTEGRAZIONI | |
App per attività | Strava, TrainingPeaks, Runtastic |
Rulli indoor | Rulli smart Wahoo e rulli dotati di ANT+ FE-C |
RISORSE ELEMNT RIVAL
Scopri queste risorse per sapere come ottenere il massimo dal tuo ELEMNT RIVAL e dall’esperienza di allenamento!
What does proper running form look like? That depends on the individual, but there are principals to understand and aim for to ensure proper individual form. Learn what that means and how to apply it to your own training.
Do These Drills, Run Faster
How do you run faster? You may think, run more...but that is not always the answer and often leads to increased injury incident. Check out tips from our experts as to how to get faster in a safe and strategic way.
Ask the Experts: Tips for Running Through Tough Terrain
Branching out to more technical terrain often involves climbing, descending, and managing your footing, and is a much different experience than the path runs you’ve been knocking out. Learn more about how the type of terrain plays into your training, your level of fitness, and overall approach.
IL MIO MOTIVO | #MyRIVAL
Tutti hanno un rivale che gli fa da traino. Scopri chi e cosa pensano di affrontare gli atleti Wahoo.
CONDIVIDI IL TUO RIVALEDIVENTA UN WAHOOLIGAN
Adopera il tag #IlMioRIVALE o @wahoofitnessofficial per essere presentati. Si applicano termini e condizioni.
