Panoramica Recensioni
Supporto per attacco manubrio per computer da bicicletta ELEMNT
14,99 €
Stem Mount for ELEMNT Bike Computers is rated 2.8 out of 5 by 20.
  • y_2019, m_3, d_20, h_2
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_18
  • loc_en_US, sid_WFCC1M2, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 42.78ms
14,99 €
  • Spedizione gratuita su tutti gli ordini superiori a € 54,99
  • Garanzia limitata 2 anni
Panoramica sul prodotto
Il nostro supporto per attacco manubrio per computer da bicicletta con GPS Wahoo ELEMNT è realizzato in plastica leggera e durevole ed è un’eccellente soluzione per i ciclisti che preferiscono tenere il proprio computer sopra l’attacco manubrio.
  • Adatto a ogni attacco manubrio
  • Peso: 0,2 oz
  • Funziona con ELEMNT, ELEMNT BOLT ed ELEMNT MINI (Nota: BOLT perde il vantaggio aerodinamico con questo supporto)
  • Include quattro (4) lacci in plastica per il montaggio
Rated 5 out of 5 by from Stem mount for Element I purchased the stem mount to put on my second bike. This is a sturdy mount that doesn't move with vibration.
Date published: 2016-12-17
Rated 3 out of 5 by from Works Fine, but expensive The mount works great and I prefer zip ties. The Garmin rubber bands get weak after being in the sun. My Garmin literally feel off my bike after the rubber band broke.
Date published: 2019-02-04
Rated 3 out of 5 by from A small fortune for this product. This mounts easily with the zip ties provided. It is easy to use and holds the computer firmly. It costs a lot of money for an item that is easily broken in a crash. This is a 'consumable accessory' and as such it should be cheaper or you should be able to buy multiple units in one order at a discount. How about even putting a couple of spares in the box with the computer?
Date published: 2018-10-03
Rated 3 out of 5 by from Must have if the aero mount does not fit the hande Works as expected but very low value for the money
Date published: 2018-07-17
Rated 3 out of 5 by from Works but there are better designs It does the job but it's expensive for small piece of plastic. I also semi-regularly swap between different bikes so the cable ties are a pain. For all their faults, the Garmin version with the rubber bands is a much better solution.
Date published: 2018-01-09
Rated 3 out of 5 by from Good,needs 1 thing. This needs an additional piece of rubber stripping to place under the stem.As sold,with the nylon ties alone,the Wahoo rotates too easily,no matter how tight the ties are.
Date published: 2017-11-13
Rated 3 out of 5 by from Works fine but way too expensive $15 for this little mount...come on. Consider this additional expense if pondering the switch from a Garmin.
Date published: 2017-07-14
Rated 3 out of 5 by from Decent, but still wy overpriced I LOVE my Bolt, and while it came with the bar mount and a stem mount, I have 4 bikes, so I need more. The bar mount is pretty cool and a bit unique so I'd be willing to pay a bit more for it, but the stem mount is nothing special. Don't get me wrong, it does the job well, but I'm having trouble with the idea of spending $15 +s/h for a piece of plastic and 2 zip ties. I know there's a minimum price point to make the shipping worth dealing with, but at least give me 2 of them for $15 if 1 for 7 isn't cost effective from a handling perspective. They cant cost more than about 5 cents to manufacture and I already gave you plenty of cash for the Bolt. Do I appreciate they shipped 2 mounts with the unit to begin with, absolutely. Do I recommend the cheap stem mount, yes. Do I feel like I'm being nickle and dimed on this item, unfortunately also yes.
Date published: 2017-04-13
  • cp_1, bvpage1
  • CLOUD, getReviews, 4.77ms
  • Peso: 0,2 oz
Caratteristiche
Per maggiori informazioni, vedi Domande frequenti
Specifiche
Residenti in California: vedere l'AVVISO relativo alla Proposta per la California 65
Recensioni
Powered By OneLink
